CE certification saw cutting machine
fish44fi
Beitrag von fish44fi »
Among those famous high efficiency multichip saw machine manufacturers, Shuoying Precision Machinery is a competitive high efficiency multichip saw machine golden supplier in China. You can get CE certificated products from us.
High efficiency multichip saw machine
Model: SYJ-4
USE AND FEATURES
The machine is often applicant to packing industry , decoration industry , PVC , EVA floor material industry and so on . It can cut whole wooden board , PVC board , EVA board into the same width thinner bars .
1.The feeding tables consists on four sets of feeding rollers . It ensures the feeding accuracy .
2.The machine has the wider absorbing dust cover and holes , it can absorb all dust completely and make the machine clean .
3.The machine can cut many thinner bars one time as per your requirements , you can adjust the bar’s width as per requirements .
4.Fast speed , high working efficiency ,save the worker’s labor
5.The wood bar’s edges are smooth after cutting .
TECHNICAL PARAMETERS:
The working width1300mm
The range of cutting thickness5-30mm
Feeding speed4-15m/min
Rotary speed2550 r/min
The min cutting width30mm
The min cutting length550mm
Saw diameter80mm
Motor power11-30kw
Overall dimension
Total weight CE certification saw cutting machine
website:http://www.chinesecuttingmachine.com/multichip-saw/
