Sock Knitting Machine quotation
fish44fi
Beitrag von fish44fi »
Basic Info.
Model NO.:YX-356
Type:Jacquard
Knitting Product Type:Sweater
Knitting Style:Flat
Knitting Method:Double
Computerized:Computerized
Certification:CE, ISO9001: 2000
Condition:New
Power Efficiency:1.5kw
Net Weight:1100kg
Knitting Width:60 Inch
Power:1 Phase, AC 220V
Trademark:YI XIAO
Specification:CE ISO9001: 2000
Origin:China Mainland
HS Code:8447120000
Product Description
Model No: YX-356
Knitting System: Three-system
Knitting width: 56inch
Gauge: 3G, 5G, 7G, 8G, 10G, 12G, 14G
Knitting Speed: Max: 1.2M/s
Knitting Function: It can realize manifold knitting methods, such as "knit", "tuck", "no knit" and "loop transfer" etc, it could finish "knit", "tuck" or "no knit" in one cam system due to the three-way-technique.
Racking: Servo motor controlled, max 2-inch racking in left or right, 1/2, 1/4, 3/4 stitch also available from any position and have compensated slighter-tuning function. With two cam systems, loops can be transferred to front and back, independent of carriage direction.
Sinker system: Moveable revolving sinkers on both needle beds make the bulge fabric and full fashioned fabric knittable on the machine, even without any old loop(add, minus needle).
Stitch density: By stepping motor. 24 section stitch selectable, adjustable scope supported by subdivision technology; 0-320, the stitch of the knitwear can be accurately controlled.
Needle selection: Eight level selection via special actuators.
Yarn carrier: 16 yarn carriers can be put at any position of carrier rail according to program setting.
Yarn storage or yarn supplier(option): Especially suitable to knit low strength yarns, such as rabbit hair yarn, high count cotton yarn.
Power-off protection: Have power-off memory function, continuation of knitting process after power-on without any waste pieces.
Stop motion: Will stop the machine automatically and give an alarm in case of yarn break, large knot, needle break, wrap around check, needle smash, racking error, program error, and pieces finish etc.
Machine status lamp: Green(normal operation), yellow(standby), red(abnormal stop).
Control system: 10.4inch color LCD panels, all kinds of date are showed on and modification possible on it. Input pattern data by USB disk. Large amount of pattern can be stored and selected to knit. The pattern designing system is easy operating.
Packing size: 2, 700× 900× 1, 620mm
Weight: 1100kg
Power: 2 Phase, 220V
Power efficiency: 1.5kw
website:http://www.weihuansocksmachines.com/sin ... y-machine/
