MIG Welding Machine Made in China
fish45fi
Beitrag von fish45fi »
Model Number: MIG-200T/250T
Feature of heavy duty mig machine
Adopt with advanced IGBT inverter technology.
2 in 1 welding machine, MIG/MMA function.
Inverter MIG welder, high rated duty cycle with high effiency.
Little welding spatter, deep welding pool, beautiful welding seam.
Technical Specifications of Co2 shield welding machine.
ITEM MODELMIG-200TMIG-250T
Rated voltage(V)220v±15%220v±15%
Frequency(Hz) 50/60 50/60
Rated input capacity(Kva) 6.2 7.1
No load voltage(V)60 60
Output current range20-20020-250
Duty cycle(%)60%60%
Welding wire(mm)0.6-1.0MM0.6-1.2MM
Protection degreeIP21IP21
Net/Gross weight:13/13.5 KGS14/16.5 KGS
Machine size: 41*22*28CM41*22*28CM
Carton size(mm)52*31*40CM52*31*40CM
Quick Details of heavy duty mig machine
Wire Feeding Speed: Adjustable
Dimensions: 520*310*400mm
Usage: Welding
Voltage: 220V
Power(W): MIG:4.5KVA /MMA:5.3KVA
After-sales Service Provided: Overseas third-party support available
PCB: Whole-bridge three pcb
Insulation class: H MIG Welding Machine Made in China
website:http://www.yamatoweld.com/welding-machi ... g-machine/
